Perform this procedure to configure the Multi-area SPB layer 2 multicast redistribution for specific I-SID value(s) in the home area.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select MultiArea.
  3. Select the L2 MC Redist Home ISID tab.
  4. Select Insert.
  5. In the I-sid field, type the I-SID value.
  6. Select Enable.
  7. Optional: In the PolicyName field, type the name of the redistribution policy.
  8. Select Insert.
L2 MC Redist Home ISID Field Descriptions
Use the data in the following table to use the L2 MC Redist Home ISID tab.
Name Description
I-sid
Specifies the I-SID value.
Enable
Enables layer 2 multicast redistribution for specific I-SID value in the home area.
PolicyName
Specifies the name of the redistribution policy.
